Hi all fellow Pantera owners. :-)
I wanted to create a common thread for all who has or are going to install Holley Sniper EFI. Thinking we can help each other and share experiences.
I'm going to install Sniper next week in my Pantera from 1974, at least that's the plan. My car - when I bought it - had a Holley racing modified carburetor, which constantly challenging me while driving. Often it would stall and be difficult to re-start. So now going for trying the Sniper when I anyway had to change the carb. Got all the equipement, so next up is to get starting to install.
But though I would connect with as many of the fellow Pantera owners having already done the conversion already also so this thread could be used for future with others wanting to go in the same direction.
I hope you hear from many of you :-)
Ps, a few things that would be interesting to hear about first is:
- Where did you place the O2 sensor? (I can see on mine, it's going to be very tricky, there's not really room many places if the installation info should be followed)
- Did you go for a in-tank og external fuel pump solution?  and if the latter, where did you place it?
- Did you feed the Sniper directly from the battery (according to the guidance) or did you find another place to to it and did it work fine?
- Did you replace the original temp sensor with the new one (Sniper kit) or locate it somewhere else?
- Did you go with coil, CD box or?
- Does it work well for you or many problems?
- other good questions/informations.
I hope you hear from you and pictures/videos are always VERY welcome. :-)
Sniper was installed during the rebuild.   I am in the dark about the installation details.   During the couple months I drove for a "shake down", either my driving skills are extremely poor or the initial setup needs some trwicking.   the car is  currenly back in shop to correct a few other problems and improving drivablity is one of the items.
the big drivablity is touchy throttle response from a stop, while feathering the clutch pulling away.  (over reving)
so when I get car back and take over maintaining, I have feeling I'll be asking a lot of questions.
I do know, the temperture sensor is the snipers in the front of the block.   Very nice having an accurate coolant temp on the display.   My dash guage sensor was installed in the water pump inlet (displays about 20F lower)
Hi jfb05177,
Great to meet you and hear your experiences. :-)
also thx on the info of the temp sensor.
when will you get your back in your garage again, you think?
I’ll update on my progress on the install very soon, still waiting some spare parts and also still creating the “master plan” for the install in my head.
I hope we’ll hear from several more. :-)
Cheers
chris
I hope you are installing the Holley Sniper2, and not the original one.  The original one had a lot of issues, even admitted by Holley engineers.  Sniper2 works magic.  I just had mine installed and finished.  It has been great thus far, and hasn't even been tuned yet.  Goes in on Monday for that.
I had the same throttle issue instantly.  Garret, the metal fabricator guru I have referred to a lot in past posts, welded an extension to the throttle arm and it fixed the issue instantly.  Now car revs up smoothly.  Prior to the fix, it was difficult not to start accelerating fast.  Basically I couldn't drive slow in a parking lot.  It just jerked forward and sped up.  Couldn't ease the throttle; now I can.
Any and every question you would have can be answered by my mechanic, Scott, who did the installation.  He has done several of these installations and pretty much did it with his eyes closed.  PM me and I will give you his contact number.
Also, I bought a tachometer adapter from Jon Haas at Pantera Electronics, which you will need to get your original mechanical tach to work with the Holley Sniper.
Fuzz
Hi Fuzz,
Thanks alot for your message, really appreciate your help and willingness to help, I'll for sure take oppertunity of that, when possible. :-)
It's the pre-2 version of the Holley Sniper. I bought it just a few months short of 2 years ago, and at that time I wasn't aware the was or would come a version 2. I didn't get around to install it before now. But now I see no other option than to go with the one I got, the version 2 is expensive like the 1 version also was, so can't afford just to buy the new one and throw the "old" one un-used away.
So'll have to cross my fingers and hope it will work okey for me. I hope the best. :-)
Cheers
Bryske
Bryske,
Have you tried calling Holley to see if it's possible to exchange or update your Sniper to Sniper 2 spec.? The main difference between the two is the throttle body. They do have an upgrade kit available (Part # 550-511-3AX - $1,099) but since your throttle body has never been used, they might do better. It's worth a telephone call.
@davidnunn, yeah, I think if I lived in USA, that could have been worth a try. Unfortunately I live in Europe (Denmark), so even if Holley is helpful, I would be looking at a very expensive exchange. You know, shipping back and forth and even worse, let's assume I got it at half price, eg 500-600$, the taxes and customers into Denmark are extreme, it would be multiples with x1,4. And I think the shipping costs would easily be 150$ at least. So though I would love to get the Snipper v2, I think it's going to be impossible. Unless you believe they would do the swap for eg 100-200§, but personally doubt that.
Hi Everyone,
I'm late to the party, but also in the middle of installing a Holley Sniper Stealth EFI system.  I bought it almost 2 years ago, but life has gotten in the way of installing it (death in the family, the birth of 2 grandchildren, the marriage of my youngest daughter, and the move of my son from Dunedin, FL to Enumclaw, WA).  In any case, I'm working on it now.  I've heard how great the Sniper2 is, but I don't see that the "stealth" model has a version 2.  Does anyone know?  I'll call Holley tomorrow morning to find out, and see if they'll exchange my new in the box Sniper Stealth for the new version 2, if it exists in the Stealth model.
I'm installing the stealth version because I want to use the stock air cleaner, which doesn't fit on the standard Sniper throttle body.  I also purchased the entire Holley ecosystem so all the connections should be plug and play. Following is what I purchased:
  • Holley Hyperspark CDI box
  • Holley Hyperspark coil
  • Holley Dual Dual Sync Distributor
    • I originally purchased the Hyperspark Distributor, but the damn thing was 4" taller than both the stock distributor and my Mallory Unilite distributor, so it would never fit under the engine screen.
    • The dual sync distributor is low profile, but it's for a 351W, so I changed out the distributor gear for a Cleveland gear compatible with my roller cam.
  • 3/8" copper-nickel tubing to fab new fuel lines.
  • Walbro #GSL392 external fuel pump, mounted to frame rail under the gas tank.
  • Bosch #17025 O2 sensor
  • Wix #33033 pre-filter
  • Wix #33482 post-filter
Now on to my questions...
  1. The Sniper Stealth requires an external fuel regulator with bypass for the return line.  I was thinking of mounting it high on the firewall adjacent to the gas tank as there's plenty of room there.  If you installed the Stealth version, where did you mount the external regulator?
  2. What wire in the stock harness did you use for your 'switched 12v' source?
  3. Did you run a dedicated wire all the way to the front trunk to connect directly to the battery as the instructions insist, or merely connected to the BATT terminal side of the starter solenoid where the heavy gauge cable comes directly from the battery?
Thanks for any info and pics, and/or additional part numbers for various fuel fittings, etc. that I will need.
@garth66 posted:
I have Terminator X for my TWM 8 stack EFI and can answer number 2 and 3.
2.  It is just the the switched 12v wire coming from the ignition switch.  Terminator X is not pulling a bunch of amps from this wire.  It just lets it know the key is in the run position.
3. No need to run a wire to the battery, just use the BATT side of the starter solenoid.
I have tested everything you see below and get spark from the coil when I spin the Dual Sync distributor manually.
  • mceclip0
Another question on the sniper install. I find that my throttle cable extends about 5/8” past the pin it connects to on the linkage for the sniper.  Did anyone else run into this?  Thinking I may need to fab a throttle lever extension bracket to extend the mount point rearward. Or possibly fab a new bracket to relocate the stock throttle cable forward 5/8”.
IMG_3549
Just curious what others have done…
  • IMG_3549
Just wanted to add my 2 cents here.  When I had my Sniper 2 installed, the throttle bracket was not moving all the way back, and thus I was not getting full throttle.  I don't recall exactly what it was hitting, but it was hitting something and the lever arm had to be extended.  I had a metal shop do that for me.  But when I took it to be dyno tuned, the guys at Race Krafters (Lancaster, PA...GREAT guys by the way) saw fuel was at 60% max delivery and hp was no where near what they thought it should be.  HP was coming in at around 290 (if memory serves me correctly), which they felt was way low for my engine.  Anyway, they took off the throttle arm, cut off the pin and moved it to the top of the lever arm, and adjusted the cable, resulting in 100% fuel delivery (according to their very impressive diagnostic machines).  After roughly 14 dyno pulls and full engine and Sniper 2 tuning, engine was producing 386 hp , with 405 ft-lbs of torque.  These numbers where at the wheel, so probably 445-465 hp at the engine. It is imperative to get that throttle body perfect or you are leaving a lot on the table.  Based on my own experience, I would say eyeballing the throttle body movement after the Sniper installation is not enough and it really needs to be tested and tuned on a dyno with folks who are experienced.  In my case, Race Krafters were/are Holley Sniper EFI dealers and installers.  I had called Holley and they looked up their dealer/installer networks and referred me to them.  I think no matter where you live, they will be able to guide you to someone who can install, test, and dyno tune the system for you.  GOOD LUCK!
@Fuzz posted:
I don't recall exactly what it was hitting, but it was hitting something and the lever arm had to be extended.  I had a metal shop do that for me.  But when I took it to be dyno tuned, the guys at Race Krafters, they took off the throttle arm, cut off the pin and moved it to the top of the lever arm, and adjusted the cable, resulting in 100% fuel delivery.
Would you post a pic of your throttle arm on the Sniper where the throttle cable attaches.  I would love to see what Race Krafters did.  Thanks!
This photo is from May when I had it dyno tuned. That is the same day the guys at Race Krafters made the required modification on the throttle arm. I don’t remember if I took the photo after everything was put on or it may be possible it has a return spring and I took the photo before it was put on. I have to get in there and look and then report back to you.
Fuzz
@LeMans850i posted:
… There is no secondary return spring installed?
there are torsional (mouse trap) springs on both primary and secondary plates.
the shop did NOT install a throttle return on mine at all.
I have a problem with idle being erratic.   I just noticed the secondary is sticking!!!!   there is a youtube showing the recentering the secondary plates (by loosing screws to shaft and retighting).    I don't want to go that far (yet) and plans today is to add an extension spring to the secondary, maybe another to cable.
@jfb05177 posted:
I would send the unit to a dealer and let them take care of the issue….
I’m Having issues with the sniper, it’s always backfired under sudden acceleration, i recently took it on the freeway and got the car up there in speed, it almost sounded like the valves were floating but it was certainly backfire, after that the car backfires through the car on any acceleration.
i just ordered a new O2 sensor that gets here today, verified and added/improved grounds.
checked compression in all cylinders.
i had the car tuned by a knowledgeable guy but not on a dyno. he thinks it’s a valve guide/spring issue because one cylinder was 5-10% higher than the other (also had a wet plug)
well known great engine builder said he only used top quality everything and believes it’s a tuning issue.
any thoughts or insights
@Bell3156 posted:
I’m Having issues with the sniper, i...
i am having similar symptoms.  (plus others)
I changed target A/F from 14.0 to 14.5.   I "think" that made improvement.  but I ease into throttle now.   I think it goes very lean with initial throttle increase.  the manual does not recomend changes to "accel pump" setting
I've notice that after change, the "improvements" occured after the next crank.  so hoping it "learns" that very little throttle opening needs extra fuel
I changed air filter because the INSIDE was black
Dan,
Before you do anything else, I'd have a look at what is causing your wet cylinder. I had a similar problem and it turned out, the rings in one cylinder had not seated properly. Ugh. The solution involved new rings and honing the cylinder. I hope that is not your problem!
It's doubtful your O2 sensor is bad although oil from the wet cylinder may be fouling the O2 sensor. When you remove it, you'll know.
Good luck!
Details- the o2 sensor(s) go in the side or top of the collector anywhere between the last pipe branch and the long extension to the muffler. Do NOT put it in the bottom of the exhaust because depending on the climate where you live, upon starting, momentary condensation in the engine runs like a river on the bottom of the pipes and water is a sensor killer. Its kind of a tricky weld job to add the screw-in boss(es) while the headers are in the car. Use anti-sieze on o2 sensor threads.
Any electric fuel pump that's the same OD as a stock Ford electric pump will fit inside the stock tank (either early or late) thru the fuel sensor hole on the top. There are two identical looking fuel pumps- one for TBI-injection (14 psi) while the other is for multi-point EFI (50 psi). Dunno which Holley specifies. You'll need to add a sealed power wire thru the stock fuel sensor top to power any in-tank pump.
Mounted inside the tank like millions of other Fords since the late '80s, fuel pumps run much quieter and cooler. There's an illustrated POCA Newsletter article from about 15 yrs ago on this. I use mine as a carb primer or emergency pump backup.
The original tach on the car wouldn't move off 1,200 without the adapter.  Both Holley (who were very helpful) and Jon at Pantera Electronics confirmed it would not work without the adapter.  And my mechanic, who is a wiring wizard, couldn't get it to work without the adapter.
I don't know the answer to your second question, other than we tried everything and the tach adapter solved it within minutes.  Easy installation and works perfectly and in synch with the Sniper II digital screen readout, meaning they show the same RPM.
I'm switching over to the Sniper 2 EFI while I have the engine out.
Is anyone using both the factory coolant temp sensor and the Holley CTS PN# 543-120?  I would like to keep the Veglia analog temp gauge if possible.
If using both where should the Holley coolant sensor be mounted?  I'm currently using the location in the front of the block by the water pump for the Veglia gauge sensor.
I will adding an electric Stewart boost water pump at the output of the radiator and use the Holley Fan output to for control.  Keeping the mechanical FlowKooler water pump on the engine.
Thanks,
John
#3590
I had the Holley sensor placed in the front of block.   (most relevant position for fuel management.
I had the Veglia semsor put in the INLET of the water pump.   (this would be near the temp leaving radiator, lower than front of block position)
I also had idiot switch placed in the swirl.   after having a couple loss of coolant and I thinking about making idiot lamp be from a coolant pressure switch
