Perhaps. If the condenser fan runs its not the fuse. Or you could check and see if you have voltage on both sides of the fuse. My first thought would be bad ground.
Don't be suprised if you loose it again. When a fuse blows it means something is wrong. If you don't connect the ignition buzzer, or use your air conditioner you just might keep it.
