Right. There are 3 or 4 sheet metal screws holding a small sheet metal splash panel in place. Remove screws, pull panel and look around the corner... A drop-cord light will help, too.
Chip; Enclosing a couple pictures from the service manual and pictorial views of the horns. As stated, they're in the right front fender, mounted on a bracket.
