The corners go where I placed a piece of blue tape in the photo below.  Cut your new D channel rubber ends so that they match the your new corners and then legs of your corners slip into the D channel.  Take your time cutting the D channel.  You can make always make it shorter but not longer.
I will be replacing the rubber on this car once I begin working on its interior.
  • mceclip0
