Silly question. I am upgrading my brakes (front at the moment) but I can’t see how to separate the hub from the rotor. I pressed out the studs. I couldn’t find any prior posts or on ProVaMo. Thanks
Hi Pantera right? take off the hub and rotor as one, from the front axis. Press the studs out per press, then the rotor comes off the hub..may need to bang a bit..
