It depends on your intended use.
A 4-Post lift is a great parking solution for stacking cars plus there are models that allow it to be moved around (without a car on it ofcourse). You can do some under-car maintenance with wheel/suspension work needing the addition of jack trays. The post gets in the way when doing wheel/suspension work.
If you do maintenance on your cars, a 2-post lift is better as there are no runners to get in the way and doesn't require add-ins. You can still use it to park a car underneath. Moving the lift once installed is difficult since the posts must be bolted.
I've got two Backyard Buddies -- love the lifts. They are no fun to put together, as they are so heavy to move around, unless you have a forklift or engine lift with a smooth floor to place the heaviest pieces.
I mainly use them for car storage -- they work great for that. Changing oil and other service work works great with these things as well as getting to the underside of the car other than brakes or suspension work. I would agree that the mid rise type of lift would work a lot better for working on brakes or suspension.
Mark
Corey,
If you want the best 4 post lift out there, don't go for the cheap crap from China. A lot of suppliers in the USA say they are built in the USA, but they are only packaged here. If you want the best mechanism that is made, Backyard Buddy makes the best one. If you find a Chinese made lift with this exact same locking mechanism and whole posts that are not made up of angle iron and straight steel pieces, then all can be forgiven. But I do not know if any of the foreign made lifts that come with this locking mechanism.
Yes, Backyard Buddies are more expensive, but they are really made that much better. I only know this because a friend of mine bought one of the $1995 delivered price Chinese made lifts and once he put it together he swore he would never go underneath it -- it is that unstable. He only uses it to store cars and will not do any work with a car on it up in the air -- it is that unstable.
I am only cheerleading for BB because I know they work -- you do not need to bolt them to the floor and they are the best out there. If you value your good health and don't want the chance of a car coming down on you, I would highly recommend one of these lifts -- and at the least, you should be looking at how they operate. The BB locking mechanism is the best I have seen in any lift. All of the Chinese ones I looked at had really screwy locking mechanism on them -- nothing like Backyard Buddy.
No, I don't work for them, nor do I get any commission from them. I am just an extremely happy owner of two of their lifts. Here is the web link to their site if you are interested:
Backyard Buddy Web Link
Best of luck with whatever you choose.
Mark
David, we were kidding too, you should leave it as a reminder of 3 important rules:
1) Don't eat too much poutine, it could spoil your girlish figure;
2) Don't visit a Hooters in remote regions of the eastern bloc;
3) If you forget rule #2, don't drink too much while you're there
Wink
Check out the Dannmar Maxjax hydraulic/electric 2 post lift. You can get it delivered through Costco to your curb for around $2000. It's designed to be bolted to the floor and unbolted and wheeled to a corner when you're not using it. A few suggestions: Make sure your concrete floor is 4" inches thick and a 4000 psi mix. Contractors cheat and make the middle of the slab thinner than the edges. Have it installed professionally for around $200. Rewire the motor to run off 220 volts. It has mechanical pin supports at 2 feet and 4 feet above the ground. I've had mine for about 6 months and it's great.
Originally posted by 4NHOTROD:
Why would the midrise get in the way? You drive right over it.
Will
I use my garage for a number of hobbies and a midrise scissor lift would get in the way of most of them, tripping over it if nothing else. Also, to lift a car it would have to be repositioned toward the center. Finally, the scissor lifts block access to much of the underbody of the car.
I have a Direct Lift 4 poster with the sliding jacks. It does everything I need it to do and I'm able to park two cars in what was one space.
The safety lock system is as good as any I have seen, all in it was about $2K if I recall, although we did it as a group buy and got some extra discount.
I considered a 2 post, but they usually have an upper cross member requiring more height clearance. That plus they require securing to the floor and you need to be sure your garage floor is sufficient for that.
Originally posted by JR428CJ:
Doc with the Dannmar Maxjax can you open the car doors?
Barely. It's a matter of getting the CG of the car where it raises evenly. I can only open the door about a foot when the car is in position to lift. I put the lift pads where the original jacking holes are in the frame. There might be other hard points you can lift at and have the car in a position where the doors can be opened. Plus, you can only space the lift columns so far apart. There are a few trade-offs. Thanks.
