The advance mechanism of a Ford Duraspark distributor "in good condition" starts scattering spark somewhere above 6000 rpm, but up to 6000 rpm it is a good distributor. When things start wearing it needs to be pulled & rebuilt.
The MSD is a much better distributor for operation at higher rpms. What folks like about the MSD distributor, compared to Mallory, Accel, etc, is that the pick up in the MSD is a Ford pick up, inductive rather than optical, and is equally reliable as the Ford unit.
The boxes are a different story. The MSD boxes have always been a reliablity handicap. I like the Duraspark boxes too, my recommendation always being the Duraspark I box (red strain relief) that was installed only in California cars, and only for a couple of year models. I have that info at home, if you want it let me know & I'll post it this evening. This particular box has no ballast resistance in the supply circuit, it runs on the full 13 volts, measures & controls current to the plugs, and is supposed to have a hotter spark. Having no ballast to worry about makes the box that much easier to install. I retro-fitted a bunch of these modules into older Fords back in the '80s.
Although I have never done it, it should be possible to wire an MSD distributor & a Ford Duraspark module to work together, this would be the best of both worlds.
Another popular module for converting ANY vehicle to electronic ignition is the Chrysler module used in their vehicles in the late '70s. It is a simple module, easily adaptable, inexpensive, produces a good spark. Lots of info on the 'net about installing it in just about anything. Mark Mensen will like that one.
For racing & high rpm use, it's best to run two of the expensive transistorized, capacitive discharge ignitions, with a cockpit mounted switch to switch to the back up module when the primary module fails. In other words, you accept the reliability issues of the CD modules & plan for an inevitable failure by installing a back up.
Your high voltage friend on the DTBB, George
