I was out taking a short drive yesterday, when the Pantera shut off..no warning. Had to tow it home.
Three basic things make an engine run, air, fuel and spark. I know I had air, I checked for fuel..ok, but no spark. I thought of the stories of dist. gear roll pins shearing, so I pulled the cap..nope..rotor turning fine and lines up with #1 cylinder.
I again pulled a plug wire and cranked the engine..yeah, no spark. Maybe that Mallory Unilite dist. went south. I went to a trouble shooting website as did as it suggested. Using a volt meter on the negetive side of the coil, I watched for a voltage drop as I blocked the photo cell..it went form 10.2 volts to 9.2 volts. The web site said it should drop down to 3 volts. Is this the reason for no spark?
I also checked the voltage at the positive feed wire for the coil. Now I have a late model 74 Pantera, with a built in resistance wire, it measured 12 volts..?? I would think it should be around 9 volts through a resistance wire..right?
By the way, its an Accell Super coil(big and yellow)
So anyway, I am stumped...I never heard of a coil just shutting off like that.
Anyway..any suggestions appreciated.
