After bringing the car down to get it tuned and aligned I am haveing a problem with the ignition switch. When the car is running and I try to shut it off it just keeps running. Then, when I switch it back to run it stops ???? This does not happen every time so I am a bit confused. Has anyone had a simmilur problem, and how did you fix it?
4416 runs great had it up to 110 and no probems.
Has anyone else notested that when you are on the highway going faster then the trafic that everyone else speeds up around you. When I had it up to 110 I had a pickup trying to keep up
Happy Halloween.
