OGraham's ignition comes with instruction on how to drill, remove the old key set and install the new.
That's great! Instructions weren't included when I ordered mine from him at the beginning of the year.
When you prepare to lubricate your lock with the graphite, you may wish to spray some 'brake cleaner' into the lock barrel first to remove the WD-40. Graphite is a dry lubricant and will be more effective if not gummed up residual WD-40 in there already.
Also, you will find that the bolts that secure the ignition switch to the steering column have had their heads sheared off, making removal another challenge. They were designed to do this when they reached proper torque. Some report using a dremel tool to slot them and remove with a screw driver. Others have used drills and easy outs, and still others have managed to turn them with a punch. All this strikes me as a lot of additional work with the potential for more frustration.
It's NOT NECESSARY to remove the ignition switch from the steering column to replace the lock tumbler. I removed the entire steering column when I replaced my ignition lock tumbler earlier this year. Undo the 4 bolts that secure the column to the underside of the dash, remove the turn signal switch (or unplug it's electrical connection), and slide the entire unit straight back and it will come right out. I wrapped the end in a plastic bag with a zip tie to keep the shaft clean and avoid smearing grease all over the wife's kitchen counter as I did the tumbler replacement according to the instructions on Pantera Place.
Best of luck!
Garth
