Help. Who has a bulletproof ignition system? I have tried MSD, Ford oem/electronic, Accel using GM module. All systems have let me down. I suspect heat releated. I carry 6# GM modules (for when they overheat) & have routed away from heat sources. I keep threatening to go back to dual point. I do not want to spend a fortune. Just want a system that is reliable. Motor has been upgraded to 350 plus hp. Have owned car 20 plus years and this has been my biggest problem with car. Thanks for the website.
MSD #8577 Magnetic Pick-up Distributor
MSD #8203 Blaster Coil
MSD #8920 Ford Tach Adapter
MSD #3119 8MM Silicone Spark Plug Wire Set
MSD #8581 Bronze Distributor Gear
MSD #6420 6AL Ignition Box with Rev Limiter
MSD #8746 RPM Module Kit 6000 - 6800
After 17 years with my car and many ignition versions and problems, the above has been totally reliable and so far bulletproof on a 520+ hp original 351C motor. I recently added an MSD box which retards the timing when cranking - solves those hot start problems.
See the rest of the details at: http://www.canspanad.com/pantera/
Hope this helps.
David
