Charlie,
Welcome to the forum! Sorry this problem has to be the motivation for your first posting.
First off.... DISCONNECT YOUR BATTERY!!!!!!
NOW!
Done? Okay, lets talk about what is going on.
You have a Pantera. They do have common electrical issues.
At this point, you may have already fried the ignition electrical portion of the ignition switch or one of your dash switches - lights most likely. Switch is easily replaced for reasonable $$, ignition switch (not as likely, though) is not so reasonable. You should probably check these areas first.
As factory wired, De Tomaso put the full amperage load through the console switches and the ignition switch, none of which were designed for such loads.
If you have not done any of the common, well-known wiring upgrades, you should be planning to do them now. Just finding the one little problem area that is giving you today's problems is not enough.
For starters, visit
www.panteraplace.
Under 'technical information' there is the electrical section. You'll see it is rather large.
Look for the Mike Drew headlight relay modification. I know of two Pantera owners who sell a ready-made kit with the relay solution: Rick Moseley and Rich Boschert and they are both in the POCA membership roster. Or you can easily source the parts on your own.
For more elegant solutions that solve this issue and add some nice upgrade features, see what fellow Pantera owner Jon Haas has come up with
at:
www.pantera-electronics.comNext you need to address the often loose connections on the back of the ammeter. See the article titled.....Pantera ammeter.
Panteraplace also has full, localized electrical diagrams under....Electrical Diagrams... that will assist in troubleshooting your wiring.
As an early? car, you may have a ballast resistor. Read up on THAT issue under the section...Pantera Starting Problems.
Check these areas, do some reading, and get back to us. I'm just one guy here, and my wisdom is mostly time-learned book knowledge. Others on the forum will be able to more accurately troubleshoot things once you discover more symptoms.
You did disconnect the battery, right?
