I had an oil leak on the inlet manifold of my car at the front of the motor(firewall end). Took off the manifold replaced the gasket and also used a very small amount of sealant and all is good. Now the manifold is leaking at the opposite end, right above the bell housing. I have been told this is a common problem with the windsor and the gasket made by Ford is inadequate. The one supplied for the rocker covers is excellent, metal and rubber combined and reusable. Is there a better gasket available aftermarket? Are there any other ways of solving this prob. Motor is a 392 SVO Stroker.
Steve
