I am getting ready to install some new rubber bushings on my ZF2 transaxle mounts. The old ones have been removed and the mounts have been polished. Is there a special tool or procedure for installing the bushings into the mounts. Any advice or instructions for doing so would be greatly appreciated as I do not want to ruin the bushings or the polished mounts!
Many thanks!
Bill
I have not yet done this particular task, but whenever I do similar...I always try and use physics to my advantage. In this case I would warm up the mount in the oven for a bit and put the bushing in the freezer for a bit. Amazing what a difference it makes. For example, I install flywheel starter teeth rings this way w/o any hammers or presses. The rings just drop into place. Just food for thought....
