I had a few made in aluminum on a waterjet machine. One was cut to fit exactly inside the plastic bezel and the second bezel was cut slightly smaller so if it was wrapped in leather it would fit as OEM which is what I had done. The one in the picture is painted. I might experiment more with the painted bezel but the one that I used was leather wrapped. These were cheap to begin with and the plastic has probably deteriorated by now. The 71-72 panel was made much better and was done in steel but the shape is close but different.
