Couldn't hurt. Not too much heat comes thru the firewall area; most seems to come through the floor and gearshift boot, from the long water pipes running to & from the engine. However, lots of engine noise comes thru the firewall & hatch area. Do a quick check: note the temperature outside & inside the car after say a 15-minute drive. Then add the aluminized stuff under the firewall upholstery, maybe under the floor & the doors and re-do the 15 minute drive. Send me the data and I'll co-write a tech article for PI, and you & your car will be famous!
