I typically use 4, one under each rear lower control arm. in the front I place them under the frame rail right behind each front tire. I have mounted the jacking pad kit from Hall (about $75) and they are located in the front where I described, across the rear crossmember and on the bottom of each motor mount.
Gary
#06984
