Name some names, george also recommended a larger pan. What is economical?
You own a Pantera and you want economical? If that is really what you want..... park it
But seriously, most common, and available at a group buy discount if you can organize another; I think there have been two already, is to go to Armando's. It's a clone to the Aviad that was THE pan ten years ago. Price is probably best direct, but check with our vendors. They may get initial discount and undercut Armando just enough - on a single pan sale - to have the lowest price. Armando's list price is $399.
http://www.geocities.com/MotorCity/Flats/1624/And if you change oil pump at the same time, avoid the high volume AND high pressure units, buy the $20 high strength oil pump drive shaft, and double up the distributor roll pins for the cam driven gear.
