Brad,
This is the first time I've seen the bumpers installed on a painted car and I really like the blue.
Just an FYI to the readers---This new style was designed as a counter part to the front splits. The most important improvement is they do not require new holes for mounting---just the impact shock hole so you can put the original L rear bumper (or fronts if you are using the splits) back on at any time.
Here's a picture of the L replacement front split bumpers.
  • ASX_chin_spoiler_(2)
I'm having trouble with my email account for the website listed as kre1@adelphia.net it is now kre1@roadrunner.com or you can try kre@adelphia.net.
If you need or want more info on the bumpers and do not receive an answer back within 24 hours, please re-send the request or give me a call.
Thanks Kirk
Originally posted by Kirk Evans:
I did a weight comparison on the bumpers today. A stock original rear bumper with impact shocks weighs 28 pounds. The new replacement split bumpers weigh 4.5 pounds total. That is a 23.5 pound weight savings. Just an FYI.
Save 23.5 lbs and good looks.....priceless. How much weight does the front bumper conversion save Kirk?
Best,
K
No, the bumpers are glass and come ready for priming and painting.
The finish and fit is excellent. I painted mine and put them on the car yesterday. Car is on the hoist so I can't get very good pictures just now, but I stood back and was very happy with the results.
My car came witht he USA L series bumper which doesn't suit the car and and I really wanted the Euro look. Unfortunately to repair the large holes left when you remove the L bumpers would require the car to be painted so I chose to go with Kirk's new design.
The car now looks fantastic and I can't wait to get the radiator back in, new windscreen fitted, and be back on the road.
To install the front, you do not have to remove anything but the old L bumper, impact shocks, wheels/tires and the wheel well shields for inner fender access.
For the back, you need to remove the L bumper, impact shocks and you're ready to install the new split rears---that's it.
The front bumpers bolt into the original 3 holes on each side and the rears have a mechanical fastening system attaching to through the impact shock holes---no drilling is needed to install the new design.
Hope this helps.
Kirk
