Hello, I would like to lower my Longchamp´s front by using the Pantera GTS rear Konis.I was told that the Pantera GTS rear Konis have a shorter spring and will fit to the front of the Longchamp perfectly. The number stamped in the LC front Konis is 82-1701 SP 1. The same Konis are in the front of the Pantera. About the rear Pantera Konis there are two different numbers mentioned in this forum. One is 82-1702 SP 1 and the other is 82-1601 SP 1. Which one is the right Pantera GTS number ? The height of my LC spring between the plates bearing it, is about 11 inches . It would be great if I could get to know what height the GTS rears have between the plates before I start this modification. Anyone who has experience with that kind of lowering the LC ?
Thanks in advance
Walt
