Installed the Hall brake upgrade kit, and among the multiple problems I discovered is that the brake booster leaks. Have checked with a vacuum pump, and it is not possible to build vacuum. As the item is brand new, what can be done ?
I beleive the item is a standard unit, anybody how knows what part no. or car it is "borrowed" from ?
None of the bolt on items was possible to bolt on. All items in this kit had to be machined, or modified to fit my "push button" car. :-(
#1155
Frode
