Gary
quote:Originally posted by comp2:
Welded up an aluminum block yesterday that was 8" wide and an inch thick. Cranked the sob up to 165amps! It was a plate that had broken. I ground a "v" where I was welding to get complete penetration. Clamped it with angle iron to keep it straight. Worked like a charm! We milled it back flat and looks like it was never broke. Gary
quote:Originally posted by jeff6559:
I was always told that you need to heat the block with a gas torch prior to attempting that kind of repair?
Detom, The car used to have Webers before I bought it. The previous owner kept them for his GT40 project. The CHI intake already sit's up pretty high:
http://www.tmeyerinc.com/400stroker.html
Hey DeTom,
I saw that. I have more intention of playing then in need of a solution. What I have will work I just wonder what I can do if you know what I mean.
I flew down to the keys thismorning. I am typing in the pilot lounge. I probably won't be back on till tonight.
Gary in Indiana...Well not at the moment!
Ha, I am a chip foose in slow motion. It only takes me 10 years to do what he does in 7 days. Truthfully, he has a lot more vision then I will ever have (even though I don't care much for his wheels). His wheels aside, he has more vision in those 7 days then many of us do in a life time!
Well Gary I have seen overflows made of about everything including plastic. So I think it is great you made one out of aluminum, because it is giving you the experiance you will need to fabricate all aluminum body panels for the Pantera, which will sell like hotcakes and make you rich and famous.
I thought about steel but don't you think a radiator over flow would be better out of aluminum? I am going to re-do the clutch tank. I may have some issues the way it's built. I can get the cap on/off unless I twist the tank. In doing so will jepordize the seal. I have been antagonizing over what I need to do and have finally come to the conclusion I just need to re-do it. We'll see how the second one comes out.
Gary
