So I attended the Chesapeake Pantera Fall Picnic this past Saturday, hosted by Ron McCall at his shop in Hampstead, MD.  What an incredibly fun time and a great turnout by fellow Pantera owners.  But my visit produced a comment/observation that has me perplexed.  I own a '72 European Pantera, chassis number 2778, verified by Marti Report that it is European and not sold in the U.S. as part of the Ford/Mercury program.  Also, verified by the original owner who brought it over from Italy.  (Just a couple of weeks ago I found a 500 lire coin in the driver's side seat rail, which was kind of neat. It must have been placed in there on purpose, because I cannot see how the coin could possibly fit inside the seat rail by the rollers.  The coin is too large to have fit through any openings.) As mentioned in another post, my car was converted to the GTS-5 wide-body back in the early 80's by Roy Waine in St. Albans, VT.  On Saturday, one attendee told me that someone had to have done a lot of work on my Pantera to convert the license plate opening to the European longer and narrower opening, because none of the Pantera's had a European license plate opening until 1981, and that all these cars had the U.S. small opening up until 1981.  (Another thread on this Forum actually states the year was 1979.) There is no visible signs that mine had been cut and reshaped, so if Roy Waine had done it, he did a FANTASTIC job of it.  So I just called Roy Waine to verify this.  He recalled vividly that he did not cut the back end of my car, and that he had received the stock GTS bodied car with the wide license plate opening.  He said during the conversion to the GTS-5 body, he had stripped down the car to bare metal, and there was no sign of any welding/body work anywhere on the car, including the license plate area. He recalls it was all original metal. Yes, I realize memories can and will fade, but he was really sure that he did not cut or change anything in the rear of the car.  Based on what I was told at the picnic and what I have read on other posts on this Forum, how can that be?  How could mine have had the wide plate opening when folks definitively state there was none until years later?  Any help to clear this up for me would be greatly appreciated.
Thank you in advance.
Fuzz
Pantera Parts Connection's Larry Stock's black '74 non-GTS car sold in the U.S has a wide rear license panel. Call him for details. We always wondered about that too. And as far as changeover dates with DeTomaso models, NOTHING was set in concrete. Ford was only interested in finishing the cars and getting them out the door. I imagine much weird stuff happened when the Pantera project cancellation notice hit the factory in early '74. You don't just unplug a stamping and assembly plant!
Well logically I would speculate that both of those US cars had rear sheet metal damage at some point and the original USA panel was changed out for the EURO panel.
I have seen absolute artists with sheet metal that are as good as plastic surgeons on faces where you will not only never see their work but not even suspect that any had been done.
I will also point out that, to the best of my knowledge, there were no USA black cars ever produced by the factory so that right there fits into a story that the black car is not original to a USA build.
Also Kevin Marti only has Ford's records of cars SOLD in the US. He does not have Detomaso's Euro records.
I was also ADVISED that in some cases with other cars Marti is fabricating "window 'stickers" with information from other sources then Ford. That I can't confirm, who can, but it is something to keep in mind when Marti's reports conflict with information from other reliable sources.
The purpose there being that they look original and the more they look original, the more that people will believe they are accurate?
EURO market cars are built to provide room for the "billboard" plates they use in Europe.
Everything you now are stating is consistent with your car being a European Market build.
I actually looked at one to buy here that was a '72 model Euro build and to my memory, it DID NOT HAVE the bigger plate indent?
The difference in size is so apparent in person it is difficult not to notice it but memory being what it is, I could be mistaken?
I didn't think much of it then since I didn't buy it because it had rust EVERYWHERE.
The seller tried to convince me that "it is just cosmetic".
It did have metal ID plates riveted to the striker pillar posts with the name of the person that imported it and an EPA certification number which I had never seen before and found to be more cautionary then interesting actually.
@panteradoug posted:
American cars back then (when I was young and in Germany)  usually got the square license plate from the “DMV” or they gave you moped license plates which is about the same as the US plate….
IMG_2443
Images (3)
  • IMG_2443
  • IMG_2444
  • IMG_2445
