When the running lights are on, the right front light is very bright, the left front is normal. Both bulbs just changed, no help.
With running lights on, The right and left rear back up lights (clear lens) are barely on, barely.
Left rear turn signal does not work. Right front turn signal does not work.
Suggestions?
Which fuse is for the RF and LR turn signals?
Where are the rear lights grounded (black wire?)
Anything else I should try? THANKS
