racheliane
if my memory serves me correctly from my 1968 Ford Torino GT with a C6 trans it is the vacuum modulator it supplies vacuum to the valve body in the trans to set the shift points. if you want to see if I am correct take the line off and plug it and if your tranny shifts at wide open throttle I am correct. The above pics are for the engine timing. Let me know.
