Last time I needed a set I just went to the local parts supply shop, and took a sample, found something with same taper and thread size. Turned out to be common to an Australian car from GM called a Holden, I'm sure there must be lots of GM vehicles that use a similar unit. They were very cheap - $30 or so.
