Originally posted by 4NFORD:
More pictures of my Mangusta after lthe front was owered 4.5 inches and smaller tires installed
Ahhh! Perfect!
I have to agree with Ford on this one...the ride height!
This is why US Panteras have the spacers under the springs.
You would never even get it into the gas station around here unfortunately.
Look out for the bottom of the bell, and i.e., the flywheel.
I don't understand what European ride height means? Our roads are better then thiers.I only worked on one 'goose'.
Who knew if it was stock or not? What's stock on a Mangusta?
I couldn't make a fist and put it between the lower extrematies and the ground, flat ground.
Forget about the concrete curbs getting into the gas stations and the cast iron/steel station tank filler caps in the ground.
We have a lot of high manhole covers in the streets too.
A 'goose' is to be looked at and not driven around here.
