Thought I had info on the sender but can't find it at the moment. Anyway, here is an additional photo of the unit, from 1010. No trace of a rubber boot as on Lee's car. A single green/black wire connects from the rear wiring harness.
Thanks, in fact I'm trying a sender that was also on my Ferrari 400i, it looks the same (!) at 16mmx1.5...if the needle moves at all, I'll be happy--Lee
