Yeah, it looks like the one from Maseratinet is right for Mangusta. The diameter and pitch/angle of the teeth are exactly the same. The Mangusta one is thicker--not at the gear but in the center washer bushings on the plastic one, the solid brass is about 2.0mm thinner than the original--Lee
Oh, simpler answer, the brass gears work for Mangusta. Once I found that the old grease is not really glue, the washers separate and are re-used for the brass.
