I checked the manifold vacuum on my car today at two locations, the carb vacuum port (timed spark port) and right on the manifold where the power brake booster hose is hooked. The carb port indicated 6" Hg and the manifold port indicated 9 " Hg. My question is why would there be a difference between the two places and based on this information which power valve should I use in the carb? The carb is a Holley 4150. I live in Colorado at 5000 ft elevation (if that has any bearing on things). Thanks.
