I was checking my fluids yesterday, and realized my clutch master has no fluid. It is a PIM unit probably bought around 5 years ago. when I added more fluid and pressurized the system the cylinder was leaking from where the reservoir attaches to the cylinder is a copper crush washer. Is this generally a serviceable part of the unit? In the grand scheme of things a new one is another $100 but $1 for a washer vs $100 is still a nice save.
Thanks, Shashi
  • IMG_7084
1. Use the reservoir from your old clutch master.  Clean it with some bleach water.
Or:
2. Remove your leaking reservoir and clean it thoroughly with hot water.  Let it dry.  Put masking tape on the outlet, mixup some JB Weld and pour it in until it is above the riveted ferrule.  After the JB Weld is hardened, drill it out.  Brake fluid does not affect JB Weld.
Or:
3. Get a new reservoir from Wilkinson.  He has a bunch of them.
