Thanks Julian and Doug.  This is what I needed.  I am cutting some aluminum plate to block off the ports on the top of the manifold in order to pressure and/or  vacuum test the plumbing for MAP and IAC along with the intake gaskets while I am at it.  I have a nice piece of 4" flat bar and will saw it into four 9" sections.  Then drill them to match the manifold and bolt them down with sheet rubber as a seal.  The lifters, pushrods, and rockers are not yet in the engine which makes this possible.
