Originally posted by george pence:
...Your diagram does not show the original relays. Do I replace them with generic relays?...
Yes. Replace them with DIN style (European) relays. They are available at most auto parts stores, in current ratings up to 50 amps DC. SPST, continuous duty. You can mount them in the oem location, and some relays have a little mounting tab on top for that purpose.quote:
...If I do, what original wires go to the new relays and to what terminals?...
The wires on the drawing marked pink are the oem wires. They run from the fuse box forward to the oem relays, where they supply both the relay coils and the fan motors. All of the original wiring downstream of the pink wires can be removed from the vehicle. The oem pink wires will connect to terminals #86 of the new relays.quote:
You indicate all new wires and I presume that is because you did this diagram for a new "SPST" fan replacement?...
The diagram is drawn for any installation involving higher power (amperage) motors than the oem motors. Which should fit the description for EVERY Pantera.quote:
...I need to be lead by the hand on this one...
No problem my friend, I'm honored to be able to help.cowboy from hell
I hate to start removing the original wires if I can avoid it. No one will remember what went on and why, including me. At least someone will be able to figure it out by looking at the original diagram.
Can't I just leave them in place, add the relays, add the new power source cables?
What size fuses for the new 10 AWG wire should there be?
What amperage DIN relay should I look for?
What's the difference between + and -?
+ flows ^ and - flows v? (Just a little joke here)...well?
