For those who have done the mod motor swap, where does the engine/crank output shaft end up? Is it higher or lower then with the stock cleveland, or about the same?
I used Wilkinson's conversion parts and with his motormounts the engine is in the same position vertically but maybe back just a touch AFIK. But to do that, either the heads need to be ground off a bit or the the wheel housing notched. Steve did the grinding for me. Richard
