Has anyone mounted Recaro SPG or Sparco Evo seats? Could you advise me what you used for mounting and what difficulties if any encountered. Thanks, Danno
i just put the recaros in my car less then a month ago it was verry easy . did you get your new seats yet because i have a costum inter being made for my pantera and will be selling these if you want
Danno. In the FWIW department, when I put in my Corbeau Forza (made it quick removable for auto events), I put on a 3/16" aluminum plate and have it move forward/back with hole selection. (I needed extra headroom). I think the EVO is basically the same kinda seat. Works fine for me, takes 5mins max to swap it. (plus the 4pt snap-in harness)
Wayne995, thanks for the info. Looked up the dimensions on both seats but haven't actually seen either one in a car or its mounting. I will have to place my butt in both to determine which is the better ergo fit for me. The mounting was really what concerned me. As long as I know sliders will fit with no hassles the solid mounts offered should not be a problem.I couldn't get specific measurements from either vendor concerning the sliders or solid mounts?
Kaamacat, your system sounds sounds alot like what I'll probable use. I was thinking about reinforcing the bottom floor pan with 1" width mild steel stripping and bolting the solid mounts offered by either Sparco or Recaro.
Danno. The plate I made actually bolts into the original mounting holes with 8MM's. For my regular seats the plate is flat, about 16"w x21" for movement. The one I use for the Corbeau Forza is angled up 1" at front for a better angle. In either case I used a cardboard template, measured 100x...etc. The aluminum plate @ 3/16 can easilly be cut with woodworking tools. (I used my bandsaw).
IN FACT.......I took my seat out (regular Pantera style) and placed in the new one before I bought it to check for clearences.
Kaamacat, thanks for the detailed information. I must say your system is creative and not something I would have thought of. I plan on doing some SCCA racing so I'll need to see if its something that would pass tech.
