i want to be able to remove my transaxel with out removing the engine. i have been told that i can simply not fit two bolts that screw to the transaxel from inside the bell housing when i refit the assembly next time, then in the future i will be able to do this.
any advice on this idear, is it safe to leave these bolts out, i guess that detomaso used them for a reason.
