Originally posted by ZR1 Pantera:
Hello "Boss"; Very Much Appreciate your "Real World Numbers"!
Based on your factual corner weights, there is NO WAY a stock DeTomaso Pantera had a 42%/58% Front to Rear weigh distribution!!!
Your weigh modifications REMOVED 604 lbs from the front & 330 lbs from the rear, yet ONLY changed the weight distribution percentile 1.5% in the front from the rear from the "CLAIMED" factory weight distribution???!!!
Was Alejandro standing on the front of the Pantera when the car was weighed at the factory??!!
Your weight modifications removed TWICE(604lbs)as much weight from the front than from the rear(302lbs) for a relatively insignificant weight distribution ratio change of 1.5%!!??
Based on those ratios & subsequent weight distribution changes, that BIG $$$$ Fontana aluminum block is going to change the weight distribution the equivalent of a couple of Cuban cigar stubs in the ash tray ...Mark
Mark,
Please explain your math? From Bosses numbers, I get 41/59 weight distribution (rounded). I also get a total weight removed of 634lbs. 180 from the front and 454 from the rear for a new weight distribution of 44/56...
Scott
Hello Scott; Always willing to explain & ALWAYS willing to be corrected!
Here is Bosses post & numbers...
"DeTomaso said Pantera wt distribution was 42%/58% frt/rear but it depends somewhat on whether you're speaking of a pre-L, an L model or a wide-body. A stone-stock pre-L was supposed to be 2932 lbs. My 'L' as driven with a 1/2 tank of gas was 3350 lbs before I started modding it. Never weighed a GT-5 or -5S. A Mangusta is 40:60.
With 30 years of modifications, our street-legal 'L' is now down to 2690 lbs as- driven with 1/2 tank of fuel; the as-modified wt balance is 43.5%/56.5% frt to rear. It will come down a bit more in back if I ever get my Fontana aluminum block finished. All-mechanical race scales are only about $250 a set if you decide to seriously start playing this game. You'll also need a set of adjustable spring-height shocks.
Our corner weights
680 lbs frt per corner stock
982 lbs per rear corner stock
590 lbs frt per corner modded
755 lbs rear per corner modded
"If", I am interpreting Bosses numbers correctly, the frontend mods removed a total of 180lbs.
The rearend mods removed a total of 454lbs.
WOW!!!...My initial numbers are Waaaaaaaaaaay OFF!!!
I BLAME Obama!!!
Thanks Scott for the correction!
...Would you like me to do your taxes for you?!
...Mark
