When I changed my clutch, That is what I HAD. Hall sent me a new flywheel and a centerforch diafram disc. All for $800! The finger type clutches take a lot more pedal effort. Not recommended. The first clutch i bought did not fit.. so I quit messing around and called the vendor. The Pantera flywheel is drilled for the 11 inch. That is why I had to buy the new one...it is drilled for the 10 1/2. I would recommend the diafram type clutch. If you can get it to mate to the 11 inch original flywheel. OK
