My apologies for the poor picture quality, but I wanted to post some pix after working all afternoon to get my new lift sorted out ...
Comments welcome.
I will post a few questions in the "comments" pane.
quote:Originally posted by EA #3528:
It is IMPERITIVE that you ensure your pulleys are all properly threaded and snug before lifting to the required height. As well, it also seems prudent to ensure that each of the four safety latches is completely at rest before walking away. I agree with the previous posts that call for concentration and caution while operating a lift. A lot could go wrong on the way up or down.
quote:Originally posted by ShotgunGrooms:
What brand and/or model did you buy? How long did it take you to set it up? Looks good, fits that area great - like it was made for it. Did you have to mod. your garage door?
quote:I had my new garage door tracks modified with a $75 "high-lift" kit which essentially is a larger curved track and it allows the door(s) to rise higher than standard.
quote:Originally posted by Joules5:
Mark,
Thanks for the comment on the idrive, a neighbor has one and swears by it, in fact he gave me one of his conventional openes for my single (third) garage door. I was getting the idrive to be able do away with my conventional chain opener (on the double door) which is ABOVE the door as it connects back to the front wall, thus restricing raising the door. I can't say I've seen one that is actually hung below?
I call around a few of the local garage door guys and see what is recommended for closing the door to ceiling gap when open.
quote:Originally posted by 4NFORD:
Looks like my Pro Park Direct lift 7. Oooh that garage door is really close to your hood! One mistake and . . .
Mine was also close and I had the garage door lifted with is higher rail that bought me another foot and a half.
quote:Originally posted by TomCat:
I leave a little tension on the pressure cylinder/cables (in both up locked position and down on the ground (at rest)) to ensure the cable stays engaged properly with the pullies AND as additional safety (if an uplock fails.
