Did you have to change to 1/2 inch fuel line from fuel tank? Is the stock line big enough to supply that engine?
The inlet to the fuel injection rail is 3/8 so that is what I went with. The line on the stock tank is just a bit smaller but the length is so short I don't think it will be an issue. I installed an in-tank pump but I don't see any reason why you couldn't use an external fuel injection pump.
Great engine swap!!, I am following in your footsteps kinda, I am installing the ls2 in mine. I have rethought the 3 valve 4.6 for the huge gain in cubic inch ablility, sound, performance etc.
I am curious did you need a new oil pan or did you cut your crossmember in pantera and which bellhousing did you use?.
I didn't change the pan. I cut out the crossmember and made a bolt in aluminum crossmember. The Bellhousing was purchased from Kennedy Engineering in Palmdale, Calif. I have a photobucket page of the whole process.
