Saturday I replaced my old 650 Holley with a new 750, with a bunch of friends from TPOC.
Today I had problems with my car all day!
Fuse # 12 blew 3 times and my battery was dead this morning...
To keep a long story short, I eventually found one of the leads for the
reverse switch/backup lamp was disconnected and grounding on the ZF.
I hooked it up, put in another fuse and everything started to work properly again.
The morale is: whenever you crawl into the rear
compartment to work on the engine, check the connections to the backup
switch after getting out and before starting the car.
