Originally posted by 4NHOTROD:
Also, how much freon does an empty system require?
Will
I converted my car to a Sanden rotary compressor and R134 with a thicker condenser than stock, but still in the same location. It took about 3.5 to 4.0 lbs to fill the system. My 1973L stock system did not have a pressure switch on either the low side or the high side, although I intend to install at least a low pressure switch when I move the condenser to the front of the car. As I recall, you can run the compressor from the switch in the car even if the system has no Freon.
