Originally posted by MARLIN JACK:
Mike, my guess is, your new alternator has the 'Built-In' Voltage Regulator (ON all the time) and the Old alt. was controlled by the External Regulator, which I believe comes ON with the key switch(I'am guessing here). That answers the mystery as to Why we get a small 'spark' when we reconnect the battery post, AND everything on the Car is turned OFF. My solution was a Battery cut-off switch, disconnecting the Grounding cable, Mounted right at the 'Pedal Box' in the front trunk. It's Also great theft protection. The only problem I have with it is; everytime I disconnect, I lose the memory of the Pre-Set channels, on my Electronic Radio. But there is a cure for this: run a 'Special' ground wire, just for the Radio, through a 2-3 anp fuse. If you try to start the engine the fuse blows. Will the drain continue through the fuse? Probably so! So this would defeat the original purpose of the cut-off. Your Multimeter for checking current draw is the smartest way of Testing! It takes all the guess work out of the equation...
Installing the fuse won't solve the issue since most battery drains are small amperage. However, they do make "bypasses" specifically designed for this application. Eastwood (and probably everyone who carries the cut off switch)has a devuce called a Computer Memory Saver. It allows a trickle current when the switch is disconnected and is bypassed during normal operations.
