Hey guys, I need some instruction on how best to install the rear side windows. How do I do this without distroying a rather expensive set of new rubbers?
You need to install a small rope aproximately the size of a law mower pull start rope around the window rubber. Use some dishwasher soap as a lubricant one person pushes from the outside and the other from the inside pulls the rope to bring the rubber lip over the body flange.
