At if you look at the end, this shows the rev limiter kicking in around 5500. Everything on mine is much flatter. It apears yours is really more set up for hp to be made at rpm. I know some of the guys will chime in here in a minut but there are 3 things I would be suspicius of:
1. Needing more power from the ignition
2. Valves loosing it at rpm
3. Fuel flow unable to keep up.
Those are my thoughts maybe the guys can rule some out or help you to rule some out.
Originally posted by comp2:
My humble opinion I don't believe this is intake or exhaust related.
Gary
.... You may have somthing there Gary. I would think the line would just flatten out if it was being choked or restricted. The power just drops off. I am no expert.
