I am looking for new tires for my 72L. Running 7" Campys front and 8" rear. Currently have a set of old BF Goodrich Euro TA's that need to go. Not sure what the max width tires are allowed on these wheels but would like to run wider tires all around if possible. Currently have 205/60/HR15's front and 255/60HR15's rear. Found new TA's at the Tire Rack with widths up to 295 for a 15" tire, but if I go wider, does my aspect ratio need to be reduced below a 60 profile to keep the overall diameter and speedo close? Thank you for any advice out there.
Ken
4433, the max allowable tire width on a given rim depends entirely on how you will use your car. If you simply enjoy the thing at relatively low speeds on your local streets and roads, run about any size you or your tire mounter can manage to get on a rim and hold air. But if you 'vigorously' drive on mountain roads, open track events, high speed cruises or autocrosses, anything wider than about 275 on an 8" rim will contribute to sloppy handing that can put you into a guard rail, even with 45-48 psi of air inside. And while that much pressure will help the sloppy handling- a little- with oversized tires on narrow rims, it will also ride rough enough to cause your fillings to swap teeth on bumpy roads.... Generally, 295 or 305s will need a 10" rim, and some competition sanctioning bodies mandate allowable tire vs rim sizes.
FWIW, Hoosier offers a Z-rated 275-50 x 15 tire that fits an 8" Campy, and H-rated tires are still readily available; while H-rating is 'only' 130 mph, that means 130 continuously for 30 full minutes- which will likely get you shot by your highway patrol in most States! It doesn't necessarily mean an H rated tire will instantly explode if you momentarily blast to maybe 150 while 'warming up the engine'. At Bonneville, H-rated tires are legal for 150-mph runs since the run-duration is only maybe 5 minutes & the salt is cool. So it depends... as I said, whatcha gonna do with the car & where you gonna do it?
Thanks Bosswrench, great advice. I have driven it a little "hard" at times, but have been taking it easy cause of the old tires I have now. I also saw your advice on putting 8" Campys on the front; now I would like to find a pair of as that sounds like the way to go to correct some of the understeer and allow a little wider tire up front as well.
Does anyone have a pair of good 8's they wanna move?? Thanks, again.
Ken
