I'm about to start putting my car back together after 8 months of minor restoration. Anyways, I'm putting on new chrome water pipes and it has no bleeder tube outlet that goes to the top of the radiator. I have a used radiator that's been serviced already from another Pantera. This radiator doesn't have a small place on top either to put the tube. Is this something that I should not even bother with, or should I do something before I put these parts in? I know it's purpose is to bleed any air that's in the coolant system. Any responses are greatly appreciated! thanks
I ahven't had the bleeder tube hooked up on my car in the almost 20 years I have owned the car. Neither my radiator nor the the stainlees swirl tank have fittings for it. I haven't had any problem bleeding the system if you follow the correct bleeding procedure. Jack the rear wheels up about 12" and get yourself a Lisle funnel which allows you to run the car with the system open and let the air bleed out.
You can get a lisle funnel through these guys, I got mine for 28 including shipping. toolcraze.com and I got it in 2 days. Their # is (818) 702-6777 and their product code is L2SRFK The cost was less than 19 but they sock on about 9.50 shipping for UPS ground.
Good luck
Gary #06984
