OK folks, here's the problem. Both the radiator fans and horn have ceased to function and of course the fan light does not illuminate. I checked and even replaced the fuse without luck. So out came the handy dandy technical manual and I may be blind, but I see no common connection (other than the fuse) between the two. However I do note that the manual wiring diagram is labeled for "73-74" Pantera's, mine is a 72 pre-L (#2492), is there a difference that is not illustrated? Before I start trying the infinite trouble shooting possibilities, I'm hoping someone may have a simple answer. Any tips are GREATLY appreciated.
Thank you, Ron
