That’s funny… I’m looking into the airflow  In multiple areas of the Pantera as well … trying to do the obvious first and get rid of the washing machine action behind the rear window cut out… The Louvers should help you that… I assume it should smooth out the airflow and make it an extraction point only… obviously, everything needs to be tested with strings attached, blah blah blah blah blah we will see…
IMG_2107
  • IMG_2107
