marlinjackThe Machinist #5723 AMARGOSA MACHINE 'Running on Empty- Middle of Nowhere'
.......Flexibility?? Or Will Not TURN? WD-40!!!! Disconnect Cable and Put a Couple of Shots Through It!! Let it Soak Over-Night! Then Spray a Lubricant.
